I2 will not read cel or datalog
Browning582
Post by Browning582 »
I have a 99 4.8 sierra. Anytime the check engine light is on I can not get to where I can read the codes or data log. I have to reprogram the truck to clear the codes then it will work until the light comes back on. Any ideas?
Re: I2 will not read cel or datalog
what happens when you try to get to the scan tool menu?
Browning582
It just freezes on the loading screen. Only way I can get it to the screen is to reprogram it so it clears the codes
please post the info.xml file from the i2 drive.
Browning582
<tool_info>
<registration sn='14U7ZATCT4' status='0' tool_oem='DIABLO_G' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r01o'/>
<application name='updater' rev='2r01c'/>
<application name='gui' rev='2r01j'/>
<application name='installer' rev='2r01d'/>
<application name='logger' rev='2r01a'/>
</applications>
<databases dbnames='2r00' dtc='2r01a' vin='2r01h' gui='2r01f'>
<database mfr='DCX' pid='2r01cc'/>
<database mfr='FORD' pid='2r01cf'/>
<database mfr='GM' tune='2r02y' pid='2r01ba'/>
</databases>
<system rev='1r01a' config='1r01d'>
<option name='Wifi' enabled='true' driver='v4.0.2_9000.20130911'/>
</system>
<last-connected vin='1GTEC14V7XZ529296' mfr='GM' calid='09373372, 16263835, 09357883, 16264165, 16264332, 16253336, 09373392, 16253353'/>
<licenses available='1' tuned='1'>
<license vin='1GTEC14V7XZ529296' mfr='GM' PCM='16263835'/>
</licenses>
<reg reg='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'/>
</tool_info>
Browning582
Any ideas
Im trying to find a vehicle to test this on to see if I can replicate it.
Nsm8404
Post by Nsm8404 »
Just had this happen to me today. Had a CEL went to check it and is stuck on the "please wait". The tune vehicle menu loads fine. Didn't try loading anything though.
Browning582
Any update on this
Browning582
Anything yet
