I've had this Trinity for almost a week now, and i'm trying to stay positive about this tuner, i want it to work but i just can see it.
I've tryed 91 & 93 Octane tune, vs original car setup, just nothing there worth buying this for, i havent found it yet anyways. I've
talked to several people, adjust this, adjust that, nothing is working, not for 500 dollars (on sale), maybe 50 bucks, this is crazy.
So far the only thing i can see this can do for me is : i can rev higher in park (whooppie) it say it can raise my speed limiter ( dont know ),
Throttle Boost seems to do a little (not $500 worth) Tick and confused!
2013 Dodge Challenger SXT 3.6L
0 to 60 - almost a sec worst now on either tune vs no tune
gas mileage, same
i thought mid-range was stronger, but put original back , not really - if any?
What a'm i doing wrong or is this thing just hype, yaa i got a tuner.
Just don't see it?
Re: Just don't see it?
if it was just hype we'd be doing a great job at selling something that doesnt work...
Are you experiencing wheel spin when you test your times? Using good fuel?
I'm not sold on the good product yet, but I want too.
Didn't change my wheel spin I left the traction control on
Same as before. Always good fuel ?
I dont recall seeing any complaints with loss of performance as stated here, can you use the tool to record a log and post the log and tunes from the device here please?
I sure can, let me figure out how to do it, im not trying to be a jerk about it, im not really, i'm just very disappointed on the performance i was expecting
and im not see it at all. I feel $500 down the drain personally. Let me see if i can get you the info... thanks
Ok, ive tryed all day to get some kind of info from this, had my laptop out in the car hooked up to the trinity, all looks good, went to the diabloviewer upload recorded log to viewer, well tryed says invaid log, maded a new one, cant read log, nothing i do works idk some times it errors say my dodge is a gm then sometimes it say reading dcx gas failed. So i got upset just restore my original backup everything seems to go in good, now i have an engine light on that wont reset, never had it before.
Okay here is what is happening atm, i restored the original backup, now have engine light, reset all parameter , make it back to all original everything. Connected the Trinity up to computer and it had an update, GM something. Put it back into the challenger, made a new backup, turned traction control off, throttle boost up 10%, rev limiter in neutral up 100, increased the speed limiter to 175 thats it. I let it go thru that process, then when finished i installed the 93 Octane tune without resetting my modified parameters. Everything looks good, no issues . Took it out for a spin, well now it won't spin a tire, not even a bark or chrip, it runs fine , at a dead stop, drop the brakes punch it , nothing not even a bark, time 0-60 was good, 6.1, the only time i could get it, every test after that in the 7's no tire spin period.... nothing consistent, ? maybe bad tuner i lost idk......
please upload one of the logs here as well as he bakcup and last tune written files from the device.
This the orginal backup.
- PCM_68171320AC.drg
- 2013 Dodge Challenger SXT
- (93.12 KiB) Downloaded 316 times
Finally after buying the Overkill tune i get results, happy now....
What is the overkill tune? Is that diablo?HitMan wrote:Finally after buying the Overkill tune i get results, happy now....
