Turning off Traction Control does not work
Like others have reported, turning off traction control does not work, i have recorded a little video so you can see i am not looking in the wrong spot
Re: Turning off Traction Control does not work
this is a known issue with 8 speed applications, would you like a custom tune that disabled ABS/ESP/TC when loaded?
ok, i understand, in that case, yes please
here you go.
Cokedoctor
I am having this very same problem but with the 5 speed automatic.
My car is a 2013 Chrysler 300S 5.7L AWD, 5 SPEED AUTO.
Thanks.
Thanks.
is the device up to date?Cokedoctor wrote:I am having this very same problem but with the 5 speed automatic.
Thanks.
Please post the tune files and I will provide a tune that disables it.
I also have had this problem with my 2014 dodge charger 3.6 since owning it. Will there be an update to cure it soon? Also does DS have any plans to have an option to disable the torque management?
this should be fixed on i2 for that vehicle.n3omatrix wrote:I also have had this problem with my 2014 dodge charger 3.6 since owning it. Will there be an update to cure it soon? Also does DS have any plans to have an option to disable the torque management?
TM is reduced/removed in the tunes to the point that its no longer in your way ideally
I have the option for tc, but when i use it ,it errors and tells me failed to update traction control. All other options work perfectly. This happens in quick adjust and modify ,immediately(doesn't wait on modify for tune write) as it is in both menus and i tried both. The i2 is up to date and i just tried yesterday.I have reset the memory on the car to no avail. I had pretty much given up on the option till i saw this thread. I will be happy to give u any more info on the matter.
Cokedoctor
Yes, it is up to date. I ran through all the updates first, before using it on my car.mikel wrote:is the device up to date?Cokedoctor wrote:I am having this very same problem but with the 5 speed automatic.
Thanks.
Aside from being unable to turn off Stability Control, I also noticed my transmission gets confused I guess you'd call it, when driving around 40mph, I go to dip into the throttle a little... expecting a downshift but instead the whole car falls on it's face, rpm's drop and is completely powerless, it lasts about a second or two, then comes back to life, in the same gear it was in before. I don't recall it doing this before the tune.
Also, will the new tune being provided have ESP/TC permanently shut off, or will I be able to turn them on/off individually with the traction button on the dash like some other models?
