'11 charger R/t traction control disabled
2011 Charger R/T max 5.7, I'm using the T1000 with the most current update of the 91 tune for the car. When ever I try to disable traction control through the programmer it screws up my transmission completely! Cant get the car to shift right feels like it's starting out in 2nd to 3rd gear and will start rolling backwards if I let off the brakes on a very slight hill. Would love to be able to use this feature but it's hard to use when it turns your trans into mush!
Re: '11 charger R/t traction control disabled
thats all you are changing?
I have the 91 tune, the transmission shift increased, and all of that works fine till I turn off the traction control via the programmer
do you get any codes when this happens?
Nope no codes at all
never seenor heard of an issue like this.
If you post the last tune written Ill make you a tune that has it disabled permanently and it should work properly.
