I2
jpperfomance
I2
Post by jpperfomance »
Hi
After updating the car at the dealer,tool required updating.After the tool updates when connected to the car I2 makes downloading,and then writes updater have been installed,pleasse press continue to reboot your i2 press continue,and so all the time again and again :crashing:
Please help
- <tool_info>
<registration sn="14U7Z5JZVV" status="0" tool_oem="DIABLO_D" updates="0" />
- <applications count="5">
<application name="vehicle" rev="2r01o" />
<application name="updater" rev="missing" />
<application name="gui" rev="2r01j" />
<application name="installer" rev="2r01d" />
<application name="logger" rev="2r01a" />
</applications>
- <databases dbnames="2r00" dtc="2r01a" vin="2r01h" gui="2r01f">
<database mfr="DCX" tune="2r01f" pid="2r01cc" />
<database mfr="FORD" pid="2r01cf" />
<database mfr="GM" pid="2r01ba" />
</databases>
- <system rev="1r01a" config="1r01d">
<option name="Wifi" enabled="false" />
</system>
<last-connected vin="1C4RJFDJ7EC179735" mfr="DCX" calid="05035872AI" />
<last-connected calid="52108920AF" />
<licenses available="1" tuned="0" />
<reg reg="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" />
</tool_info>
Re: I2
can you attach the actual info file please?
jpperfomance
Re: I2
mikel wrote:can you attach the actual info file please?
Send you to mail
jpperfomance
Re: I2
Send you to mail
Hi Michael
After several attempts to update the tool file is deleted
Please tell me what could be the problem
jpperfomance
Re: I2
jpperfomance wrote:
Send you to mail
Hi Michael
Re: I2
the update is loaded, you should be able to load the update to the vehicle then tune it.
jpperfomance
Re: I2
mikel wrote:the update is loaded, you should be able to load the update to the vehicle then tune it.
Return to “Ignition updater”
