New to the forums and to Tuning, but I'm a software engineer and NOT new to computers...
1st, yes I'd rather have a hemi, but got this car insanely cheap, too cheap to pass up...
Bought the iTune2 and the programmable PCM direct from Diablosport, and I always do updates on the computer before trying to do an update on the car..
Let me start by saying that I'm a very HAPPY customer, this little box really brings the 3.6 to life!
Of course first just did the Easy Tune, put in the 93 octane tune and noticed a HUGE difference right off the bat.
But I wanted to disable Traction Control so I don't have to hold down the button every time I start the car.
Note that I have NO problem turning it off by holding the button on the dash while pressing the start button, so I figured it would be easy for the iTune2 to disable it permanently.
It is NOT...
First as a Software Engineer I have to say your menu system is NOT very easy for a newbee to understand... and none of the manuals have anything about the advanced options or what they do... However being an engineer I think I got it right, or I hope I did... A FULL complete manual would help a LOT... I would never think of releasing software without covering all the possible screens and what each option does...
Basically here is what I want:
I want the 93 Octane Tune PLUS the following:
Traction Control OFF
Throttle Sensitivity bumped up to 15%
That's it... First I went into Advanced Tune, the only option available was "Install Standard Tune", Install Custom and Modify Parameters were grayed out, OK I haven't bought a custom, but I did want to modify a tune... anyway I selected "Install Standard Tune... (only choice I had...)
In there all I had to choose from was "Diablo Tune", "91 octane Tune", "87 Octane tune"and "Modify Stock Tune"... But I want the 93 Octane Tune...
I remember reading in here that "Diablo Tune" WAS the 93 Octane tune (why not just SAY "93 Octane Tune"?), so I selected the "Diablo Tune" and continued....
I then went into "Modify Parameters".
Had no trouble bumping up the Throttle 15%...
But when I tried to "Set Traction Control to Disable", it thought for a second then said "Failed to update Traction Control" - Continue... (At least you don't say "OK" like Microsoft does
I got the same message trying to Enable the Traction Control...
I've tried this multiple times, always get the same result...
When turning the car on, the dash does NOT show it as disabled like it does when I do it manually.
Again this is with the PCM I bought direct from Dialbosport.
And I have NO problem disabling it via the button on the dash, I can set it to "Sport" by pressing it when the car is on, and I can turn it OFF by holding the button during start...
Other than that I'm loving your product!
Pete
PS. Speaking of updates via the computer, when I plug it into my USB and select Settings --> Advanced Options --> Override installed tests (Yes or No) --> Check for updates, it always says that there are updates and do I want to download them. I do so, but if I repeat the process, it STILL says that there are updates. I doubt that there are updates on a Sunday afternoon 10 min apart... should I ever expect it say "Already up to date, check back later"? Or is that just the way it works?
I can do the same thing running inTuneUpdater2.exe from i2/Updater/Windows/ on my PC...
It will always copy updates to the device and tell me that I should be in the disclaimer or main menu and to wait for it finish updating...
I never have any problem installing the update (takes like 3 min), but it never says that it is up to date...
If that's "just the way it works" fine... Just want to check everything is OK with the device.
