PCM Calibration
PCM Calibration
Please advise. xml attached. thnx I have tried updating everything for the last 4 hours and I'm starting to drool on myself from exhaustion.
Re: PCM Calibration
its not asking for an update, what are you trying to tune here?
Re: PCM Calibration
I get this messag. No parameter adjustments are available and are grayed out.
Re: PCM Calibration
click the green check mark then go to the pc and run the updater, if it does not download the file post the new info file here please.
Re: PCM Calibration
I completed that process several times. After clicking the green check box, I then plugged the unit into my pc, it said no updatest needed. I tried this several times, with the same results.
Re: PCM Calibration
Re: PCM Calibration
connected, no updates, here is the info.xml as of now..
Re: PCM Calibration
its still not asking for an update.
When you click the green check mark does it then ask you to go plug it into a pc?
Re: PCM Calibration
Yes, I will hook it up again shortly to reconfirm.
Re: PCM Calibration
I checked yes on the programmer when asked if I would like to recalibrate. it then said to unplug and connect to a pc. When I did that, this is what I got. I attached the info.xml again. it appears to have the same date on it? It appears it is the original file and is not being updated like it should when disconnected from the vehicle. Is there a way to manually send/edit an info.xml in this case?
Re: PCM Calibration
the request is there now, I will have this fixed shortly.
Re: PCM Calibration
So, it turns out this is an odd cal, is this an old Mopar PCM?
Re: PCM Calibration
I spoke with tech support, looks like it wont work with my vehicle. I wanted to be sure I got it correct, the DCX will do 2011-2014 Dodge RAM hemi?
