PROBLEM WITH UPDATING AND USING IT WITH WIFI
Re: PROBLEM WITH UPDATING AND USING IT WITH WIFI
Hello!
Is there any updates?
please reboot it in the vehicle and that should clear up.
HELLO!
Can you check what's the problem? Every time I connected the device to my car the following messages as shown in the picture was showing.
THANK YOU SO MUCH!
wehowardjr
The first screen you're supposed to press YES.
Yes I press YES and then the second picture will show. Only like this.
tune vehicle will only be lit up when connected to a vehicle.
So it was showing that it wasn't connected to the vehicle? How can I connect it again?
wehowardjr
With ignition off, plug the cable into the OBDII port under the dash. Plug the other end into your i2. Wait for it to power on, and follow the onscreen instructions.
I make it already but the only message coming was the 2 pictures above. :'(
wehowardjr
That's odd. Hope the Diablo guys can get it figured out for you. Good luck.
so with it plugged into the vehicle you still only have settings lit up?burini7 wrote:I make it already but the only message coming was the 2 pictures above. :'(
HELLO GUYS!
I hope everything is good on your side!
My device is already working. Thank you so much for all the help! HAVE A GOOD DAY!
wehowardjr
burini7 wrote:HELLO GUYS!
I hope everything is good on your side!My device is already working. Thank you so much for all the help! HAVE A GOOD DAY!
That's awesome news. Glad to know you finally have it working.
