Mike,
I need help with the trans tune on my ATS. Currently running the hard Diablo trans tune. Is TM totally disabled by default with this tune or do I need to manually disable it? It feels like it's interfering currently by fluctuating the throttle. Today it was 31deg F and the motor was running super strong, (BNR tune, Denso 22 plugs and TRS intake) but I swear the TM was spoiling things. I also had TC and ST disabled with the long press.
Lastly, I asked BNR if they could tweak the trans tune but Jerry said there was a bug with the CMR software that was not allowing them to read the trans tune file. What's up with that?
Thx, J
13' ATS 2.0t Trans tune questions
Re: 13' ATS 2.0t Trans tune questions
Im not familiar with a trans tune bug in cmr....ask him to try and let me know if he has an issue.
ANy TM left on should not be getting in the way, there are lots of reasons for the pcm to close throttle though, logs are generally needed to determine why it happened.
olineallthetime
When I last spoke to him about this issue two weeks ago, he said that he had contacted Diablo but that a resolution was not offered. What should I do?
Jerry usually contacts me directly, I dont recall this coming up, but please ask him to contact me so I can figure out what bug he's referring to and get it fixed.
olineallthetime
Done! Thanks Mike.
I got in touch with him, hes been busy moving and hadn't seen that I had already sent him a fix for the issue he was having with your tcm, I'm sure he'll get to it as soon as hes settled in to the new shop.
