I2020 Not Working
KellyDynge
I2020 Not Working
Post by KellyDynge »
This tuner was a replacement for My original tuner that was made obsolete by an update from Ford.
After installing it in My 2012 Ford Raptor 6.2L, it kept throwing DTCs, due to the cat delete. It wasn't an issue with the original I1000.
I returned to stock & tried to install on My other truck, a 2009 F150 5.4L, but received a "vehicle not supported" even though the tuner was updated to the latest software when I received it.
Just to make sure, I tried to tune My friends 2005 F150 5.4L & received a "failed to read" message.
What does this tuner work on?
Re: I2020 Not Working
it works an all 04-16 and some 17 F150s.
Please post the info.xml file from the i2 drive so we can check it out.
Getting codes for cat delete is normal until you have a custom tune to disable them.
KellyDynge
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_F" status="0" sn="14U7Z6UI9D"/>
-<applications count="5">
<application rev="2r01r" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01k" name="gui"/>
<application rev="2r01d" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01f" vin="2r01h" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD" tune="2r02k"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
-<system rev="1r01a" config="1r01d">
<option name="Wifi" enabled="false"/>
</system>
<last-connected vin="1FTPW14V69FB01966" mfr="FORD" calid="RXFM4R2"/>
<last-connected calid="9L3P-7J104-EB"/>
<licenses tuned="0" available="1"/>
<unsupported vin="1FTPW14V69FB01966" calid="RXFM4R2" oem="FORD"/>
<reg reg="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"/>
</tool
KellyDynge
Still not working.....
save this to the i2 drive and let the device import it then you should be able to tune that truck.
KellyDynge
Will do. Thank you
