Any updates for camaro ss 2017 support.
carmos70
Post by carmos70 »
Hi just checking in on updates for my camaro ss 2017.i have ur in tune I purchased abit more than a month ago..
Re: Any updates for camaro ss 2017 support.
close, keep an eye out.
carmos70
Post by carmos70 »
Hi will there be an announcement of the update. Or do I just try to update my new in tune till it works. Thanks.
there will be an announcement in the forums and on their main site when 2017 support is out and available.
17 trucks being released today, Camaro/Corvette early next week ;)
carmos70
Post by carmos70 »
Thanks for the update Mike. :D
CSevenGS
Post by CSevenGS »
mikel wrote:17 trucks being released today, Camaro/Corvette early next week ;)
It's late next week, still nothing....
DiabloSport Now Supports 2017 Corvette and Camaro
We're very excited to release 2017 Corvette and Camaro tuning coverage on the industry-leading inTune i2 and Trinity tuners!
Pre-Loaded Performance Programs
2017 Camaro SS 6.2L
· Diablo Performance Tune 93+ Octane | +15 HP / +20 TQ
· 91 Octane Performance Tune | +11 HP / +16 TQ
· Modified Stock Tune
2017 Corvette Stingray/Grand Sport 6.2L
· Diablo Performance Tune 93+ Octane | +20 HP / +30 TQ
· 91 Octane Performance Tune | +15 HP / +22 TQ
2017 Corvette Z06 6.2L Supercharged
· Diablo Performance Tune 93+ Octane | +30 HP / +30 TQ
· 91 Octane Performance Tune | +25 HP / +20 TQ
Adjustable Parameters
· Gear Ratio
· Tire Size
· Active Fuel Management On/Off
· Fan Temp Adjustment
· Fueling Adjustment
· Idle RPM Adjustment
· Rev Limiter On/Off
· Speed Limiter On/Off
· Spark/Timing Adjustment
· Throttle Sensitivity Adjustment
Silver2011
Post by Silver2011 »
06MonteSS wrote:DiabloSport Now Supports 2017 Corvette and Camaro
Super! Question: Will we be able to retain the factory drive train warranty when returned to stock?
carmos70
camaro ss 2017 support. install not working after update 5/4
Post by carmos70 »
i tried to install the tune from my intune 2 after updating it today.i get all the way to the part where it says reading ecu.then it goes to a screen where it says. original at the bottom and exported at the top.then almost immediately it changes screens and this one says read error and at the bottom it says continue.i hit continue and it takes me back to the screen that says 93 tune and 91 tune and it begins the process all over again.i tried it 5 times with the same results.Please i need help with this .my car is a camaro ss with auto trans 2017.
Re: camaro ss 2017 support. install not working after update
carmos70 wrote:i tried to install the tune from my intune 2 after updating it today.i get all the way to the part where it says reading ecu.then it goes to a screen where it says. original at the bottom and exported at the top.then almost immediately it changes screens and this one says read error and at the bottom it says continue.i hit continue and it takes me back to the screen that says 93 tune and 91 tune and it begins the process all over again.i tried it 5 times with the same results.Please i need help with this .my car is a camaro ss with auto trans 2017.
please post the info.xml file from the i2 drive.
carmos70
Post by carmos70 »
please post the info.xml file from the i2 drive.[
how do i do that ? thanks for your help with this.
carmos70
Post by carmos70 »
is this the file you mean ?
when you connect to the vehicle it should prompt you to connect to a pc and run the updater, have you done that and run ignition after connecting to the vehicle?
it looks like you did try once, but the server was down, please start again at the caR, then go to the pc and run ignition again, then you should be able to tune it.
