N2O with Trintity 93 Perf tune?
Wondering when I install this 75-100 hit of Nitrous to my 5.7 Ram 1500 can I still run the Perf tune I have installed from my Trinity?Or will the timing and fuel ratio be all jacked up? Hoping I didn't just waste money buying Nitrous and or a tuner that won't run in harmony together. Anyone have experience with this?
Re: N2O with Trintity 93 Perf tune?
ideally you should be using the tuner to pull some timing at WOT for use with N2O.
Thanks Mike, I knew that and know it should be around 2 degrees with the 100 shot but....where in the world in the tuner do I pull timing?I don't see that option? Could you explain where in the tuner I do this?
also would I need to make my own tune out of the canned tunes or use original backup tune to adjust?
after you select the tune choose the modify tune option, then modify parameters, then you can adjust the timing as needed under WOT spark.
