Trinity got no adjustable parameters after update for JK
sawahaoe
Post by sawahaoe »
after the last update to my diablo trinity ! i couldn't find any option to change tire size or to change the ratio or traction control !! what is the problem ? i cannot even change the throttle boost !! :crashing: :crashing: :crashing: no Adjustable Parameters at all ?
sawahaoe
Re: No options for (tire size/ratio/TPMS/traction) after upd
Post by sawahaoe »
my car is Jeep Wrangler Rubicon 2014 AT
Re: Trinity got no adjustable parameters after update for JK
tire size is in the quick adjust menu.
to get to the params, select the tune, choose the option to modify the tune,. then you will see the params.
sawahaoe
Post by sawahaoe »
mikel wrote:tire size is in the quick adjust menu.
after choosing the tune there are two options
one to install and the other to modify
from modify two options
one to modify parameters and the other to reset all parameters
from modify a message shows "parameters are not available for this vehicle/transmission combination/4"
so what is the solution ?
OK, well, thats not right :)
Please go to options/troubleshooting/show calid and tell us what the calibration ID is.
Also, options/show info, and tell me what the version is please.
sawahaoe
Post by sawahaoe »
here is the calibration ID :68192927AC
and the version is : V.1r13a
boot loader version: 19.78
sawahaoe wrote:
mikel wrote:
sawahaoe wrote:
Thats the current calid in the vehicle?
What tune selections do you get?
sawahaoe
Post by sawahaoe »
mikel wrote:
What tune selections do you get?[/quote]
93 Octane "Diablo" Tune
this is corrected in the next update.
sawahaoe
Post by sawahaoe »
mikel wrote:this is corrected in the next update.
so what to do now ?
it will be fixed when we release the next update.
sawahaoe
Post by sawahaoe »
mikel wrote:it will be fixed when we release the next update.
WTH !!!!
And when is that ? How long it takes?
I need to change the ratio and disable traction!! How can i get back to the previous update ?
WTH !!!!
here you go, the update is attached.
trinity_dcx_gas-1t13ba_update.crom
(10.99 MiB) Downloaded 361 times
fede.kory
Post by fede.kory »
Hi good day. I have problems adjusting the parameters of the vehicle. I miss an error that is as follows.
Parameters are not available for this vehicle / transmission combination. (4)
It is a RAM 1500 laramie manufactured year 2016
In the trinity I figure this:
PCM: 68274575AB
Vercion: v.1r13e
fede.kory wrote:Hi good day. I have problems adjusting the parameters of the vehicle. I miss an error that is as follows.
PCM: 68274575AB
Vercion: v.1r13e
please load this update to the device after restoring the stock tune then try again.
trinity_diablo_dcx_gas-1r13f_update.crom
(11.18 MiB) Downloaded 308 times
