2o13 f150 platinum ecoboost misfire and limp mode
robinsdt
Post by robinsdt »
Not sure what's going on but whatever tune I use, the truck misfires and stalls upon acceleration and sometimes the gas pedal doesn't work for about 1min then it's ok. Dangerous! No check engine lights.
Help appreciated!!!
Re: 2o13 f150 platinum ecoboost misfire and limp mode
are you making any changes when you load the tune?
do you have the updated spark plugs?
robinsdt
Post by robinsdt »
Mike, only change I made was tire size. I just ordered the spark plugs and will gap them and install. I'll let you know if it helps.
OK Sp534 plugs?
Gap to about .028-.030
