ignition issue
ignition issue
im trying to install ignition it gets about 3/4 of the way done in the setup process and just sits there at microsoft.net framework 4.5.2. ive used the file from my I2 and downloaded it from the site and both do the same thing. any suggestions?
wehowardjr
Re: ignition issue
Have you tried installing using Run as administrator when you right click on the file?
Re: ignition issue
yes ive tried everything i know to do. i got my wifi set up so i am able to update the tuner over wifi but id like to be able to do it with a computer too.
Re: ignition issue
what version of windows are you running?
Re: ignition issue
did you get this resolved?
If not, go to the site
http://fusionupdate.com/ignition/powert ... taller.exe
instead of running the file, select save as and save it to your desktop.
Now go right click on the file you just saved to your desktop and left click on RUN AS ADMINISTRATOR
especially with HOME editions of Window you have to elevate permissions to install certain things that modify crucial system files and the .net framework modifies crucial system files.
