Ok things were good then I modified predator tune turning off egr and air and increased mph in 1st at normal to etc and now Speedos 50% fast!
I might have gone into ratio and re entered the 3.73 ratio but it was already in there
When I check now Ratio and tyre size is correct
2000rpm in drive shows 60mph instead of about 40!
Help!
Thanks scott
Speedo off fixed
scott tomcat
Speedo off fixed
scott tomcat
Re: Speedo off
Got it fairly accurately now but had to set gears to 5:13 will this have any negative impact?
scott tomcat
Re: Speedo off
As i was getting no advise decided to remove predator tune, then with original back on speedo was correct.
Reloaded the predator tune and now its ok , checked the gears was correct at 3.73
Went into the tyre size and it originally comes up 00's in all fields so I recon adding the correct sizes here must have messed up the speedo readings -guess this field doesn't work properly.
