PCM read fail Mustang 2006
All3nAnt
Post by All3nAnt »
Hi, how are you, I write because a few days ago I bought the diablo sport intune i2 i2020 to improve a ford mustang model 2006 but at the moment just after the ignition is removed and then put back the diablsport says PCM reading error and I do not know what happens , I unplug the halogens that is the only thing different from the factory of the car.
Thanks for the help.
Re: PCM read fail Mustang 2006
can you post the info.xml file from the i2 drive here please?
All3nAnt
Post by All3nAnt »
Thank you for taking care of my query so quickly.
Attached below are the requested XML files.
Code: Select all
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_F" status="0" sn="14U7Z5WLQX"/>
-<applications count="5">
<application rev="2r01r" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2t01lc" name="gui"/>
<application rev="2t01eb" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2t01gf" vin="2r01h" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD" tune="2r02k"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
-<system rev="1r01a" config="1r01d">
<option name="Wifi" enabled="false"/>
</system>
<last-connected vin="1ZVFT82H365195376" mfr="FORD" calid="FBNF255"/>
<licenses tuned="0" available="1"/>
<reg reg="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"/>
</tool_info>
its a bit out of date, please update it on a pc using the ignition software and it should be good from there.
All3nAnt
Post by All3nAnt »
Thanks for the help, I will try and then notify you if the problem is solved. :D
