Three different 2017 ZO6 Corvette's not Supported by Diablo
FreeAmr, 8850 and myself can not get the Diablo InTune to connect. FreeAmr and 8850 have been sent second units to try and they do not work either. Our procedure is : 1. Take the new InTune out of the box and update it with IGNITION through the Internet. Then connect the Intune to the aldl. Then hold the start button for 20 seconds to put the vehicle in RUN mode. Click yes, click Tune to get the seed from the ECM. Then we get VEHICLE NOT Supported, click continue (supposed to have the seed at this point). Then remove InTune and connect to the internet through IGNITION to update InTune again to get a KEY to match the SEED. Then back to the car, 20 seconds, RUN, yes, Tune.
WE STILL GET VEHICLE NOT SUPPORTED
If we press ? We get no vin #
We have updated multiple times with the same results.
ANY HELP WOULD BE APPRECIATED.
Re: Three different 2017 ZO6 Corvette's not Supported by Dia
Best to call customer support on Monday. May have to wait for a few calls, but it is the best way to go.
robbieroflcopter
Make that 4. What do I need to provide to get my car on the supported list?
robbieroflcopter wrote:Make that 4. What do I need to provide to get my car on the supported list?
You are now with us. Possibly 2 more coming over. I'm sure Diablo will have a fix soon. We need every 2017 ZO6 on the list that the DS will not support to give Mike@Diablo the best data base to work with.
Thanks for posting.
Pics
pics
if you click the ? from home screen then select vehicle info with key in RUN, does it display the VIN on the screen of the device?2rpierce wrote:Best to call customer support on Monday. May have to wait for a few calls, but it is the best way to go.
if you click the ? from home screen then select vehicle info with key in RUN, does it display the VIN on the screen of the device?robbieroflcopter wrote:Make that 4. What do I need to provide to get my car on the supported list?
also please post the info.xml files from your i2 drives here.
If you look at the 4th pic posted it shows a screen shot of what happens when you click ? In RUN. Under VIN it shows NO VEHICLE FOUND. WE ALL GET THIS MESSAGE.
robbieroflcopter
That is correct: no VIN in that screen. It won't pull codes or do anything. It's powered up but doesn't seem to be talking to the car. Oh Mylanta!
Here it is.
robbieroflcopter
Here's mine:
thanks guys, for some reason the tool is not getting the VIN on these vehicles which is the first step in making it all work.
We are digging into it.
robbieroflcopter
I've been sitting in my car in my garage for hours. I'm ready to tune this bad boy!
