2016 Charger one tune on the trinity???
General Trinity Support
capcas
Post by capcas »
I bought an unlocked PCM and a Trinity for my 2016 charger 3.6L and there is only one Tune, the Modified Stock Tune and I cannot adjust the parameters. Where are the rest of the options mentioned on the Web site listed below.
•93 Octane Performance Tune: 15HP 20TQ
•91 Octane Performance Tune: 13HP 15TQ
•Calibrate Speedometer for Gear Ratio
•Calibrate Speedo for Tire Size
•Cooling Fan Control
•Throttle Booster
•Fuel Rich/Lean Adjustment
•Spark Timing Advance/Retard
•Idle RPM
•Top Speed Limiter
•Rev Limiter
Chuck
Re: 2016 Charger one tune on the trinity???
capcas wrote:I bought an unlocked PCM and a Trinity for my 2016 charger 3.6L and there is only one Tune, the Modified Stock Tune and I cannot adjust the parameters. Where are the rest of the options mentioned on the Web site listed below.
•Throttle Booster
•Idle RPM
•Top Speed Limiter
•Rev Limiter
Chuck
load this update to the tool then you should see the tunes.
trinity_diablo_dcx_gas-1r13f_update.crom
(11.18 MiB) Downloaded 306 times
capcas
Post by capcas »
I will download and test
thanks
Ken Sheaffer
Post by Ken Sheaffer »
I don't have the same issue, but am still a bit confused. I now have the canned 93 tune, but can't change my rev limiter, gear ratio, fan control or top speed. Am I correct or missing something? I like the canned tune but would like to set some shift points to get more accuracy at the track. I also know that shift points are different when in sport mode. Can I adjust these per mode?
If we can't change any of these items when using the canned tunes, then what good is changing the rev limiter and top speed with a stock tune? Happy with product so far, but am now starting to feel a bit as if my hands are tied.
Ken Sheaffer wrote:I don't have the same issue, but am still a bit confused. I now have the canned 93 tune, but can't change my rev limiter, gear ratio, fan control or top speed. Am I correct or missing something? I like the canned tune but would like to set some shift points to get more accuracy at the track. I also know that shift points are different when in sport mode. Can I adjust these per mode?
there is no shift point adjustment available for these vehicles currently. TCM support is in the works.
Return to “General Trinity”
