Transmission Temp
Transmission Temp
What PID is this called? I selected the one that says "TRANS TEMP? but it just stays at 40 all the time, there must be another one somewhere? Thanks
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
Predator
V.9r11
RE: Transmission Temp
Are you refering to "J1850 TRANS OIL TEMP" on the J1850 node in DV? Please record a log with the PID (about 5 seconds worth is sufficient) and runtime.txt found in My Documents\Dataviewer. Either postup or email it to [email protected]
Re: Transmission Temp
Tried to check the transmission temp on my 300c srt8 2006 today using the "J1850 TRANS OIL TEMP" PID. Same thing happened to me. Showed -40C and didn't change as the engine got warmer.
- RichardGhval
Transmission Temp
у меня по коробке пишет такую вещь
1 Fault Found:
17095 - Transmission Fluid Temp Sensor G93: Implausible Signal
P0711 - 35-10 - - - Intermittent
что этото и как с этим боротся
1 Fault Found:
