Hello
I'm fitting my 2000 z28 stock ls1 4l60e with à 3600 vigilante tc. Do I need tuning ?
If so is it possible with my predator and what to do ?
New 3600 converter 2000 z28 tuning ?
Re: New 3600 converter 2000 z28 tuning ?
tuning will help for sure, at least raising the lockup speed, custom tune will be required for these types of changes.
Many thanks for your advises.
Is the custom tune you mentioned, possible with my Predator ?
Is it possible to raise the Lock up with Predator ?
If these tunes are not possible with stock Predator, is it possible to get a custom file to enter in via a pc or other?
Also I didn't mentioned, I also changed my stock 2.73 rear end for a 3.42 one.
Engine is stock with k&n lid and Magnaflow rear muffler. Everything else is stock
For that I found in the Predator where to adjust the new ratio, upshift MPH and RPM.
Until now, this car was my DD one and has 100 000 miles on the odo now.
My goal is a high 12 without internals.
you'll need to get the tune from one of our cmr tuning dealers, the Predator will not let you adjust that yourself.
