Hello all. I installed a procharger supercharger kit 2 weeks ago. this one to be exact. http://www.ebay.com/itm/331590332244 but i got the upgrade to the kit which included a new upgraded fuel pump, 39lb injectors, MAFia, and the intune i2 programmer.
Myself as well as my partner at my garage did the install and double checked the install. Everything is properly done.
I loaded the tune procharger sent me and attempted to start the vehicle. it wouldnt start unless held WOT and then it shot out lots of black smoke and wouldnt idle. ran very rich. I reloaded the stock tune and the car runs and is drivable but runs rich and I get 4 codes. basically saying both banks are to rich and both banks O2 sensors are at max limit.
I have been playing email tag with the tuning department at procharger and they have sent me a bunch of tunes now and none of them ever work. The last email i got said that diablosport thinks they figured out whats going on and to try this last tune. NOPE same exact thing!
every tune i get from procharger immediately throws a code of P060c. but when i load the stock tune the car is drivable with only rich codes. with the stock tune the idle is very low and when i am stopping it sometimes shuts off. after 3500 rpm it runs great. anything under 3500 and it bogs down.
procharger said the intune may be reading a different code but i used a stand alone scanner as well and it says the same thing. p060c.
my car is bone stock except for flowmaster after axle exhaust and 4:10 gears. 50,000 miles. 2006 mustang gt 4.6l
i am attaching the tunes procharger has sent me. the one labeled diablo is the last one they sent saying that should fix everything. Also my MAFia is set to position #2.
Can anyone PLEASE help me with a tune that works?
PLEASE HELP! 2006 supercharger install, no tune works!
DiabloMatt
Re: PLEASE HELP! 2006 supercharger install, no tune works!
hey buddy could you email me directly so i can get this resolved for you? [email protected]
DiabloMatt
never mind. found your ermail. im emailing you now
diablomatt you're the man! in case anyone else runs into this problem, make sure you're putting the tunes in the correct spot on the intune i2.....
