2017 Silverado 5.3 A6
leadfart
Post by leadfart »
My Trinity has the latest uploader and crom, it has worked fine on my 07 Corvette, and my old 14 Silverado. I just bought a new Silverado, with an April build date, tried to use the Trinity, and get the dreaded update tool. What gives? I am an experienced Trinity user, as well as other tuning software. Thanks for any help.
Re: 2017 Silverado 5.3 A6
the 17s require an additional update.
assuming the tool was updated prior to going to the truck, you just need to connect it to a pc, open dsdl, let it find the tool then it will put the device under remote control for a few seconds, from there it will go back to the main menu and then you can go tune the truck.
leadfart
Post by leadfart »
Well, I figured that it was probably something like. The tool was updated before trying the new 17. I have tried doing what you suggested, it doesn't appear to be finding an update. Now, instead of prompting to update the tool, it gives me a failed cut message, with details of pcm read error (-1). I usually figure this stuff out, this one is stumping me so far. :twisted:
failed cut generally indicates that the unlock info hasn't been received yet. Can you tell me what the version is under options/show information?
When you went to the pc did you see it behave as I mentioned it would before going back to the truck?
leadfart
Post by leadfart »
The exact verbiage is failed cut, then in details, PCM error prepare read, (-1). I have no clue, just a shame this tool and software can be so difficult to use. If I can't figure it out, it goes into file 13, with a lot of other hod rod stuff!
leadfart
Post by leadfart »
Yes, it would go in and out of remote tool.
leadfart
Post by leadfart »
version v.1r13x
leadfart wrote:version v.1r13x
please load this update to the tool with dsdl then try it again in the vehicle.
trinity_gm_can_gas-1t13yi_update.crom
(2.86 MiB) Downloaded 489 times
leadfart
Post by leadfart »
Winner, winner, chicken dinner! I downloaded the new crom, and it booted up, just like it's supposed to, the first try! I installed the Diablo tune, with the firm shifts. Took it on a little test drive, shifted fine, and no MIL's. :mrgreen: Thanks again Mikel, for your prompt attention. Whatever you did, it worked. 8) 8)
glad to hear it, enjoy ;)
Return to “Trinity GM Gas”
