2017 5.3 Silverado - DOD\AFM Not Disabled
2017BlackOut
Post by 2017BlackOut »
Hi,
I have a 2017 Silverado 1500 2wd with the 5.3 and 6L80 transmission. When I disable AFM\DOD the truck is still switching in v4 mode. I have tried modifying the stock tune to disable this and modifying the 87 tune (the tune I would like to use). With both of these I am still going into v4 mode.
As it stands now i am running the modified 87 tune with DOD disabled.
CROM version = 'gm_can_gas-1r13w 04/12/2017 06:00:46 PM boot3'
Name: PCM, TuneID: 87 Octane Tune, Modified: yes, Lock: No, Erased: No
PCM_677878678668.grg
Original Backup
(129.32 KiB) Downloaded 942 times
PCM_677878678668_87_Octane_Tune_modified.grg
87 Modified Tune (Current Tune)
(6.25 KiB) Downloaded 790 times
Any ideas on how I can disable DOD?
Kevin
Re: 2017 5.3 Silverado - DOD\AFM Not Disabled
2017BlackOut wrote:Hi,
The attachment PCM_677878678668.grg is no longer available
The attachment PCM_677878678668_87_Octane_Tune_modified.grg is no longer available
Kevin
please restore the stock tune to the vehicle then load this update.
Then reload the tunes and let us know if the AFM disable is working.
trinity_gm_can_gas-1t13yj_update.crom
(2.86 MiB) Downloaded 1364 times
2017BlackOut
Thanks for the quick response! I will do this after work and reply with details.
2017BlackOut
I loaded the CROM then installed the modified 87 tune (DOD\AFM disabled). Unfortunately I'm still going into v4 mode. Please let me know if I can provide anything to help get this sorted out. I won't be able to do any uploads or get details from the tool until tonight sometime.
Kevin Nolle
2017BlackOut wrote:I loaded the CROM then installed the modified 87 tune (DOD\AFM disabled). Unfortunately I'm still going into v4 mode. Please let me know if I can provide anything to help get this sorted out. I won't be able to do any uploads or get details from the tool until tonight sometime.
Kevin Nolle
Please export a new copy of the backup and last tune written files from the trinity and post them here.
2017BlackOut
Loaded
TCM_276638284444_Trans_Hard_Shift_Tune.grg
(3.25 KiB) Downloaded 949 times
(6.25 KiB) Downloaded 828 times
Backup
(129.31 KiB) Downloaded 733 times
TCM_276638284444.grg
(57.52 KiB) Downloaded 872 times
2017BlackOut wrote:Loaded
The attachment TCM_276638284444_Trans_Hard_Shift_Tune.grg is no longer available
Backup
save the attached file to the trinity then load it to the truck.
if there is still an issue with AFM coming on, please post a new copy of the pcm last tune written and we'll check it out.
PCM_677878678668_AFM.grg
(107.43 KiB) Downloaded 853 times
2017BlackOut
Thanks Mikel! I appreciate the support, I'll get it loaded and report back with details.
thanks, looking forward to it.
Pdotwee
Post by Pdotwee »
Please let me know also when someone has the correct update or solution to this problem. Been back and fourth with different updates and even tried a custom tune.
2017BlackOut
Unfortunately I am still going into v4 mode. Here is the tune that was loaded. Please let me know next steps. I appreciate the help!
PCM_677878678668_pcm_677878678668_afm_modified.grg
(6.25 KiB) Downloaded 814 times
It shows modified but that is just because I went in and confirmed AFM was disabled before loading. No parameters were changed.
Pdotwee
Post by Pdotwee »
Has the problem been corrected? When will a update work with the truck?
we have resolved this.
restore the stock tune to the vehicle, load this update, then all the params will work.
trinity_gm_can_gas-1t13yo_update.crom
(2.87 MiB) Downloaded 1395 times
2017BlackOut
Outstanding! Thanks Mike. I will get this loaded tonight or tomorrow at the latest and reply with results.
Pdotwee
Post by Pdotwee »
Everything worked just fine. Stays in V8 mode and so happy! Thanks again!!
Return to “Trinity GM Gas”
