2006 jeep trinity tuning problems (turbo)
scott2005
Post by scott2005 »
This is a 2006 jeep wrangler unlimited. running 6 lbs boost running rich 9.0-9.8 air/fuel (wide band) at 5lb vacuum to 2lbs of boost cruising speed.. running 27lb injectors 1 bar map factory ecu
Is there anyway to get a tune for this setup or point me in the direction of someone that can help me. Im in WV. Or do yo think going back to the factory injectors and modifying the factory tune by adjust the fuel and timing would work
Re: 2006 jeep trinity tuning problems (turbo)
you need a custom tune, but you also need more injector, and a 2 bar map like the SRT4 MAP to allow it to properly work with boost.
