2017 Silverado No Flextunes showing up
Hello,
My truck is a 2017 5.3L 6 speed with flex fuel. I have filled up with E85 and was looking for the 91/93 Flex tune. But it isnt appearing as an option. I have the 87 tune and the Diablo tune available. I loaded the Diablo tune, firm shift, AFM off, speed limiter off, recalibrated tire size. The truck runs good, but not any noticable more power than the stock Chevy E85 calibration. Any advice on finding the correct tune? Thank you
Re: 2017 Silverado No Flextunes showing up
we only offered the flex tune for 14 models as they were all flex equipped, starting in 15 some were not, and its not easy to tell whats what, so we didnt want to offer it for no flex trucks and cause problems.
Let me look into making it for you.
Can you post the PCM backup file from the tunes folder on the i2 drive here?
Hopefully I did this correctly
Here is the TCM as well.
Here yo go.
Save this to the i2 drive and let the tool import it then load it to the pcm and you can run 93 or e85, and the gains with e85 will be awesome
Awesome! Thank you very much. Quick question: I saved the new file to my tunes folder. Then when I plugged the intune into the truck, I am not seeing where i select this tune. I am unable to find the location of the file. Do you know what the name would be? I am seeing 93, 91, 87, and mpg boost in the easy tune. And Diablo, 87, and mpg in the advanced. I've looked under the settings as well. Sorry I am new to this
you don't copy it to the Tunes folder subfolder.. you need to just copy it to the main i2 drive itself.. intune screen will show it loaded, press continue on the screen, and you're good to go..
If you're a Mac user, you have to drag it into the main i2drive then hit eject and do it over again until the intune confirms it was written.
ahhh nevermind, i think i figured it out. disregard my last post. I did it wrong the first time. Now to go plug back in the truck.
mikel wrote:Here yo go.
quick question i have a 2018 silverado reg can 5.3 and i added the flex fuel sensor to my truck and i have the i3 dianlo tune installed but want to run e85 would i be able to use this file also to be able to use flex tune ?
can i have the same thing done my flextunes arnt availible i have the i3 handheld and want to tune with the e85 tunesmikel wrote:Here yo go.
no, that tune is specific to his vehicle and device, and will only work for a factory flex fuel application.cokero94 wrote:mikel wrote:Here yo go.
let me check with the cal team.cokero94 wrote:can i have the same thing done my flextunes arnt availible i have the i3 handheld and want to tune with the e85 tunesmikel wrote:Here yo go.
mikel wrote:let me check with the cal team.cokero94 wrote:can i have the same thing done my flextunes arnt availible i have the i3 handheld and want to tune with the e85 tunesmikel wrote:Here yo go.
was it able to be created
here yo go.
Mike - any chance you can add flex fuel to my tune?
