f150 EB3.5 P2282
cpove
f150 EB3.5 P2282
Post by cpove »
I have a thread going in the itune section but it should be in this thread as im using the predator PN7102.
Called you guys today for a tech call as im having issues with check engine lights. Techs are checking things out I guess but just want to let you know code that is thrown is a P2282. 2017 F150 EB3.5
does not show a CEL on the dash but when plugging in the device it shows up in the DTC section.
cpove
Re: f150 EB3.5 P2282
Post by cpove »
Anything?
when you called in id anyone ask you to send tune files or the info file?
if not can you post the info.xml file and the files from the tunes folder here so we can check them out?
cpove
Post by cpove »
I cant locate the tunes folder or a file called tune.xml?
sorry, I was thinking intune.
when you called i were you asked for your serial number?
were you given a case number?
cpove
Post by cpove »
No case number given. Was just told on the phone that it was being looked into about ghost codes.
cpove
Post by cpove »
over 3 weeks old guys...any updates as to where we are heading with this? I cant use the tuner at all in its current form.... :roll:
do you have any drivability issues when the code appears?
cpove
Post by cpove »
yes. The truck jerks very hard and the traction control flashes on. Also threw a wrench code one time and was forced to pull over and clear codes with the programmer.
cpove
Post by cpove »
hey guys,
I'm trying to be patient and all, but its been over a month now at this point and all tunes are completely unusable in their current state. Are we getting anywhere with this? Any updates to be had? :|
cpove
Post by cpove »
Couple months now. Unit is still throwing codes after the update I received. P2282 and p099a/b
this is in the engineering queue to be looked at, they are trying to source a vehicle that replicates the issue.
Sorry for the delays.
Return to “Predator Ford Gas”
