2016 Mustang not compatible anymore???
StangATX
Post by StangATX »
Greetings,
I brought my car to Ford last time for a reflash. I tried to tune my car and for some reason the tuner didn't tune it all the way in and I restored it back to stock. After a couple of miles a light came on and car didn't wanna start. I let it off for an hour and try to start it again. Somehow it started with a check engine light so I brought it to Ford and they told me that they had to reflash the ECU and all the other stuff because it wasn't communicating properly for some reason. (I'm guessing it was due to the bad flash :normal: ). Anyways, Got my car back since 2 weeks now. Yesterday I filled it up with 93 Octane and at the moment to flash it I had an error message. I went home updated my tuner and tried it again and I still get the same error message. any ideas of what's happening? It worked fine before :crashing:
Re: 2016 Mustang not compatible anymore???
please post the info.xml file from the i2 drive.
StangATX
Post by StangATX »
mikel wrote:please post the info.xml file from the i2 drive.
<tool_info>
<registration sn='1FSY7KDKTJ' status='0' tool_oem='DIABLO_F' updates='0'/>
<applications count='5'>
<application name='vehicle' rev='2r01w'/>
<application name='updater' rev='2r01e'/>
<application name='gui' rev='2r01m'/>
<application name='installer' rev='2r01e'/>
<application name='logger' rev='2r01a'/>
</applications>
<databases dbnames='2r00' dtc='2r01a' vin='2r01h' gui='2r01g'>
<database mfr='DCX' pid='2r01cc'/>
<database mfr='FORD' tune='2r02l' pid='2r01cf'/>
<database mfr='GM' pid='2r01ba'/>
</databases>
<system rev='1r01a' config='1r01d'>
<option name='Wifi' enabled='true' driver='v4.0.2_9000.20130911'/>
</system>
<last-connected vin='1FA6P8AM(REST OF MY VIN)' mfr='FORD' calid='FNGS1F3' spn='GR3A-14C204-EBA'/>
<licenses available='1' tuned='0'/>
<unsupported calid='FNGS1F3' vin='1FA6P8AM(REST OF MY VIN)' oem='FORD' spn='GR3A-14C204-EBA'/>
<reg reg='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'/>
</tool_info>
I covered my VIN because I'm sure Ford does some google search sometimes. Let me know if you really need it and I'll send it over PM. I tuned that car before I brought it to Ford many times and since Ford reflashed it due to a bad comm it's not working anymore. So I know it worked before. Also, the software says it's the latest update installed but on the website to download each file manually it's another version for Ford,... Anyways, Hope you can help me fix that problem.
PS: While my car was at the dealer. My brother in law let me borrow his SS and his car blew up the belt on the road and I got some DTC. I used the tuner on the SS to check the DTC and clear the DTC. I doubt that would've messed it up though :punisher:
Thanks for your time!
save this to the i2 drive and then try tuning it again please.
StangATX
Post by StangATX »
mikel wrote:save this to the i2 drive and then try tuning it again please.
Do I save it at the root of the i2 drive?
Edit: NVM I moved it at the root and it updated the tuner. I will check this out after work tonight. Hopefully that will work I'll keep you posted tonight.
Thanks for you time!
StangATX
Post by StangATX »
Still not working. I keep having the same error message. :blowup:
Here's my XML information:
<tool_info>
</applications>
<database mfr='FORD' tune='2r02m' pid='2r01cf'/>
</databases>
</system>
<last-connected vin='1FA6P8AM(THE REST OF MY VIN)' mfr='FORD' calid='FNGS1F3' spn='GR3A-14C204-EBA'/>
<unsupported calid='FNGS1F3' vin='1FA6P8AM(THE REST OF MY VIN)' oem='FORD' spn='GR3A-14C204-EBA'/>
<reg reg='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'/>
</tool_info>
I apologize, I missed the part where you got updated by the dealer, we'll get this added in the next couple of days and post an update here for you.
StangATX
Post by StangATX »
mikel wrote:I apologize, I missed the part where you got updated by the dealer, we'll get this added in the next couple of days and post an update here for you.
From what they told me. They didn't update it. It was already at the latest version. They just reflashed everything to fix the error comm. I really hope it can be fixed though. I'd hate to be stuck with a $400 dollar product. There's no way to reset some files or something on my i2?
save this to the i2 drive and let the device import it then you can tune the vehicle.
Sorry for the delay.
StangATX
Post by StangATX »
I will try it today and let you know. No worries about the delay I didn't have much time either this week. Thanks again Mikel! I'll keep you posted :mrgreen:
StangATX
Post by StangATX »
It worked! Thanks a ton man! So, I'm guessing Ford updated my ECU? :normal:
Yes, they did :)
StangATX
Post by StangATX »
Y'all are the best! Thanks again Mikel! :-D
Return to “i2/i3 for Ford vehicles”
