I have an aem x series wideband hooked up now to my car and I have the mono jack running to the trinity and I am getting a reading from the analog but it is in volts!
So I tried changing limits from from 0- 5 volts to 10 to 19.98 but it still reads volts.
the volts move just right along with afr wideband, but how do I make the volts read to afr ratio numbers in the trinity?
Im sure Im missing something simple but I have hit so many buttons in the trinity I gave up.
asking for help.
Thanks Dennis
Trinity convert 0-5 volt analog to read afr in trinity
Re: Trinity convert 0-5 volt analog to read afr in trinity
I go to options
I get to the screen that says volts and I change to afr and I get to a screen that says lower limits I type in 10 and then up limits type in 19.98 save that go to pick that as a gauge and it just reads volts.
I need a step by step, sure I'm missing a simple step.
you have to create a gauge called AFR or similar and assign it to the same channel as the analog input so it displays in AFR.
Its all covered in the trinity user manual.
