Hi,
I unregistered my 2013 Ford F150 to take it to the dealer and have my PCM updated to the latest Ford calibrations / TSBs.
Device shows 0/1 Licensed, so I know I did unlock it.
Tool has the latest updates. Ver 1r04j
Tool Serial number J26356A-4
My truck now has a different strategy code with the PCM updates, which was expected and is why I unlocked it first.
After the dealer update, I plugged in the Intune assuming I'd have to go through the process of hooking it up to the car, then downloading the backup via internet, then installing the tune, but instead it says "vehicle not supported". This is the same car/VIN that WAS tuned the day before.
What do I do / update here???? XML file is attached.
I thought maybe I need to "Delete Vehicle" from the tool to start fresh, but that gives me some code and wants a password after.
Unlocked InTune "Vehicle Not Supported" After Dealer Update
- info.xml
- (2.14 KiB) Downloaded 259 times
Re: Unlocked InTune "Vehicle Not Supported" After Dealer Upd
strike that.... I plugged the device back into ignition and it said the ford tune was missing. It Re-updated it and the ford tune is there and I seem to be going through the setup normally again.
good deal.
