Hello,
Just purchased a new tuner for my 2017 1500 Silverado 5.3 w/4l80. Is there a way to tune the top speed and rpm? It says diablo value only. Also when tuning trans, would 25% of tune for torque be less torque management than say 75% of tune? Also is there tuning in the 93 octane tune for the trans already? Thanks in advance adam.
Predator 2
Re: Predator 2
there is no adjusting torque management for the tranny.. it's either on or off. if you have the 6 speed tranny, yes it can be tuned.. if you have the 8 speed tranny, no it can not be tuned at all, only the engine can be tuned.
Re: Predator 2
I just got off phone for tech support. Was told trans is not supported yet for the 2017 Silverado 4l80 on predator 2. I had options on first tune, and now they are gone.
Re: Predator 2
yeah, the predator 2 is a little more limited than the intune i2 i2030 or the Trinity.. may not have all of the same adjustability, and you can not do custom tuning for it either.
Re: Predator 2
Thank you for the tech support. Will the other two be able to tune the trans on the 2017 Silverado? If so maybe I will exchange for the more options, or will this one be able to potentially in the future with updates?
Re: Predator 2
If you have the 6 speed tranny, yes the inTune i2 i2030 and Trinity both support and tune it on the 2017's.
Re: Predator 2
Hello Lew, just wondering if the inTune i2 i2030 turns off torque management or is it not as simple as enable or disable? I guess when I selected it I couldn't really tell the difference, is there any way to verify? I would rather turn it off altogether unless that is not possible. thanks
2016 Silverado 5.3L 4x4 Z71 6 speed
Re: Predator 2
most is didsabled in the tune, you should have an option to disable whats left in the TCM params.
tech@diablosport.com
