Tuner (tool) doesn't recognize that it's plugged in
KennyPowers
Post by KennyPowers »
One problem after another. The ignition updated seems to be trying to update
But now the tuner does nothing. Refuses to recognize update
KennyPowers
Re: Tuner (tool) doesn't recognize that it's plugged in
Ignition updates now states that device is up to date !
However I plug into truck (14 ram 1500 5.7) and it says update required
Vehicle not supported.
its asking you to check for an update for the vehicle now.
Please post the info.xml file from the i2 drive here.
KennyPowers
here is the xml file
info.xml
(1.86 KiB) Downloaded 280 times
KennyPowers wrote:here is the xml file
the device is missing a critical file and will need to be swapped out, can you give us a call so we can set up an rma?
Let the tech know your i2 is missing the installer file.
KennyPowers
ok, thanks
KennyPowers
purchased a second intune tool directly from diablosport now mike, it just arrived.
I plugged into the PC and did the update, returned to truck and received the same message vehicle not supported please update. how do I proceed?
KennyPowers
mike here is the most current xml file if that helps
info.xml
(1.84 KiB) Downloaded 292 times
it just wants you to connect to a pc and run ignition to get the update for the vehicle, then load that update to the vehicle then you can install the tunes.
