Data logging 04 duramax
The actual fuel pressure pid has disappeared. Have reinstalled app and reset tool.
Re: Data logging 04 duramax
what changed?
what device are you using?
did you update the tool or DV?
Updated data viewer.. have tried multiple older versions and still not showing as an avalable pid.
Pid was still there after update bus was not reading correctly. Retrived vehicle info again and it disappeared
try clicking display infrequently used pids in dataviewer.
mike it has to do with the vehicle update revision 2r01w. i installed an earlier version 2r01u and everything is back to normal. might want to have your guys check it. i also was missing the pid folder "intake"
reverified. resinstalled the newest version for vehicle. got intake folder back but still no actual fuel pressure in the diesel folder.
And now I can't get the pid back after I reinstalled the older version
the vehicle app shouldnt have any effect on what PIDs are displayed in Dataviewer at all.
We are looking into this.
Never been able to read diag codes either
can you post one of th elogs that had the pressure pid and specify for me which pid it is by name?
actual rail pressure is the pid that goes missing.
and are you logging directly to the device or streaming to DV on a PC?
Directly to dv. Didn't seem to datalog on device alone.
please try this:
try requerying the truck while connected. (5th button from the left on the toolbar).
