Cannot update until registered, but can't register
Re: Cannot update until registered, but can't register
gsamford4818 wrote:I'm having the same issue as most people here. I can't get my I-1000 to update and I have tried using the registration file that has been used here many times. Every time it reboots it says it can't be updated until it is registered.
My email is [email protected]
the device is not registered, you need to use the file I posted last 3 posts above this one.
gsamford4818
Post by gsamford4818 »
Ok I got it registered and updated, but now I'm having another issue. After selecting the tune I want and it starts reading the original backup, it freezes up and never gets off 0%. What do I need to do now?
Nevermind...I figured it out. I had to update the firmware. I had to download the InTune-1r03y.itf file first and then run the update. Once the firmware was updated it worked with no issues. Wanted to leave this on here in case anyone else runs into the same issue.
info.xml
(603 Bytes) Downloaded 320 times
