Stuck checking for updates
Wont let me do anything, just stays in the Checking/Installing Updates Screen Please Wait ......
Re: Stuck checking for updates
can you post the nfo.xml file from the i2 drive please?
I am not sure how to do that, but I sorta solved my issue, when I unplugged my WiFi so there is no WiFi to try to connect to here and it lets me tune, but soon as my WiFi is plugged back in , its stays on the Please wait screen indefinitely...
Kretzments
Mikel,
I'm having a similar problem. Trying to update it, but it keeps giving me an error message about it timing out and cold file retrieval error or something like that. I've attached my info.xml file as well. Thanks for any help.
Bob Kretz
Bob Kretz
you can disable wifi in the settings menu if that helps.Hawk412 wrote:I am not sure how to do that, but I sorta solved my issue, when I unplugged my WiFi so there is no WiFi to try to connect to here and it lets me tune, but soon as my WiFi is plugged back in , its stays on the Please wait screen indefinitely...
Ya I tried that, for reasons I don't know, it wont disable it, says it worked then goes right back to trying to connect, strange, so for now I just turn my wifi off in the house until I am done, that seems to work for nowmikel wrote:you can disable wifi in the settings menu if that helps.Hawk412 wrote:I am not sure how to do that, but I sorta solved my issue, when I unplugged my WiFi so there is no WiFi to try to connect to here and it lets me tune, but soon as my WiFi is plugged back in , its stays on the Please wait screen indefinitely...
