2016 Ram 1500
2016 Ram 1500
Hi after checking the quick adjustments on my trinity I wasn't able to find shift points or traction control or any of the parameters shown On the website the only one that is shown on my trinity is wheel size. The main reason I bought the trinity was to get full traction control off.
Re: 2016 Ram 1500
shift point control for a 56 speed will be in the modify parameter menu, the 8 speeds will be added in the very near future.
TC disable should be in the quick adjust menu so we'll need to look into that.
If you export a copy of the last tune written using dsdownloader I;'ll make you a tune with TC disabled for now.
Re: 2016 Ram 1500
oh alright i guess ill have to wait for the shift points. but yeah if you can give me a tune to turn off traction control that'd be great
- PCM_68265855AF_Perf_91oct_modified.drg
- (4.25 KiB) Downloaded 299 times
Re: 2016 Ram 1500
the attached file disables TC so there will be no ABS/TC/ESP when this tune is loaded.Juanm3700 wrote:oh alright i guess ill have to wait for the shift points. but yeah if you can give me a tune to turn off traction control that'd be great
- PCM_68265855AF_NO_ABS_TC_ESP.drg
- (97.84 KiB) Downloaded 296 times
Re: 2016 Ram 1500
i wasnt able to get the tune on the trinity keep getting this error message. also included the original backup file
- PCM_68265855AF.drg
- (126.13 KiB) Downloaded 300 times
- Capture.PNG (8.18 KiB) Viewed 9326 times
Re: 2016 Ram 1500
use this one.Juanm3700 wrote:i wasnt able to get the tune on the trinity keep getting this error message. also included the original backup file
- PCM_68265855AF_no_ABS_ESP_TC_new.drg
- (98.89 KiB) Downloaded 303 times
Re: 2016 Ram 1500
Hi so I updated the trinity so I can get the transmission tune but can't seem find the transmission tune. Please help
Re: 2016 Ram 1500
is it a 6 speed or 8 speed?
Re: 2016 Ram 1500
whats the version on the device and part under options/show information?
Re: 2016 Ram 1500
I went to options, show info and took picture of what it showed
- 9EE1FC45-F16F-4BE3-BDF7-9D9B12C4D8E8.jpeg (2.62 MiB) Viewed 7057 times
- A73BF6ED-AAA1-43B0-BF3C-B1B6E8E01479.jpeg (2.31 MiB) Viewed 7057 times
Re: 2016 Ram 1500
the device is not up to date.
It should be on the new dcx_gas_15 crom and even the diablo_dcx_gas version is p to 1r13i.
Restore the stock tune to the vehicle and let dsdl update the device.
Then select the vehicle.
On the next screen it should ask if you want to choose (dcx_gas_15), let me know if not.
Re: 2016 Ram 1500
Oh yeah I got it now thanks
