Help! Tuner won't connect to truck?
Lehmbeezy
Post by Lehmbeezy »
So I've been using the Diablo trinity on my Chrysler 300 for 6 months no problems but now that it's off the road for winter I unmarried trinity and want to use it in my 02 Chevy Silverado 1500hd but it keeps saying can't comment to pcm or something similar please Help!!!!!
Re: Help! Tuner won't connect to truck?
Anything aftermarket installed in the truck? i.e did not come from the factory?
You need to make sure anything aftermarket is disconnected/pull the fuse for - anything like aftermarket stereo, subs, amps, nav, alarm, remote start, seat heaters, trailer brake/light setup, etc.. anything like that, their wiring harnesses need to be disconnected/pull the fuses for it before you try to tune anything...
also make sure everything is turned off inside the truck.. lights, radio, heat/fan/blower, do not operate power windows, put your parking brake on, etc...
Lehmbeezy
Post by Lehmbeezy »
06MonteSS wrote:Anything aftermarket installed in the truck? i.e did not come from the factory?
It has aftermarket radios and trailer break controller I'll try unplugging both those first tomorrow..
Return to “Trinity GM Gas”
