Updated I2 and now vehicle not supported
Updated I2 and now my 2017 JGC 5.7 is not supported
. "info.xml" attached
Re: Updated I2 and now vehicle not supported
Bump, can't tune my car. Please help.
I'm working on getting it added now.
Insert Clever comment here...
download this update, load it to the i2 then you can tune the tcm.klein1j wrote:Updated I2 and now my 2017 JGC 5.7 is not supported. "info.xml" attached
Its a good idea to go back to stock first if you havent yet.
https://drive.google.com/open?id=0BysXg ... TVhdW50Qms
- Downloaded and confirm the tool updated.
- Hooked up to car and said vehicle is unsupported.
- Hooked up to ignition to see if I need an update, and got "Unsupported file for your calibration not found".
- I unmarried the tool yesterday before doing anything further.
- I saw a similar / same topic where multiple calibration ID's had to be downloaded before it was resolved.
- Please advise.
- Please advise.
Any update? Should I call in?
save this to the i2 drive, let it import the file then load it to the vehicle then you can tune it.klein1j wrote:- Downloaded and confirm the tool updated.
- Please advise.
Works, thanks... I can use the canned TCM tune with my custom PCM tune, right? Just want to make sure.
yes indeed.
