Hello
I do not have the option to remove my TPMS light or even adjust the tire pressure please advise
TPMS i2 tuner
Cadmanbruce
Re: TPMS i2 tuner
First off why would you want to remove the TPMS light? Secondly, that should come up in settings on your Uconnect screen on your radio. I think you can turn it off there. (Okay, I found out I can't turn off my TPMS sensor in settings but I can turn off my blind spot indicators if I wanted to not that that's much help to you). The TPMS gage has nothing to do with performance. And, if it's on you've probably got low tire pressure on one of your tires. You can't adjust the tire pressure setting on the screen. It just measures what you have in the tires which of course you can put more air in anytime.
Are you looking for a tire diameter adjustment because you've changed tire sizes? Or, are you running drag radials without TPMS sensors or with lower pressure and the indicator light stays on because of the low pressure?
Bigalsjkru
Re: TPMS i2 tuner
Hello
I have a 2013 Jeep jk rubicon and I’m running 35” tires and would like to shut of the tire pressure light on my dash
Re: TPMS i2 tuner
can you post the info.xml file from the i2 drive please?
