Not sure why it was worded that way, but anything with an 8 speed is supported for 2015+ applications.
2015+ ZF8 TCM tuning now available
Re: 2015+ ZF8 TCM tuning now available
I guess that's what happens when marketing writes copy and doesn't have the technical people review it.
Hi I installed the update. It says it was successful but i dont see anything about transmission tuning
Hi, could you please post what the update does?
Another user asked about shift RPMs, and the response was that they have not been changed, so what tuning changes have been made for the ZF8 tranny? Shift firmness, then?
We want to know what the update does, please!
Did you notice any difference in how the transmission behaves?Juanm3700 wrote:Hi I installed the update. It says it was successful but i dont see anything about transmission tuning
Mike Comp T/A #57
I had my shift points raised to 6400 RPM. What a difference!
- IMG_7636.jpg (295.69 KiB) Viewed 11858 times
bennyd3000
Mikel, what exactly does the tranny tune change? I am assuming shift firmness? If so, how does it work with cars equipped with Sport mode, or track mode? Thanks, really considering buying this based on your response.
firms up shifts, reduces some TM and addresses some converter slip settings.bennyd3000 wrote:Mikel, what exactly does the tranny tune change? I am assuming shift firmness? If so, how does it work with cars equipped with Sport mode, or track mode? Thanks, really considering buying this based on your response.
Modes all work the same, changes apply in all modes.
supercooper
Will this work on the 8 speed for 2014 also or no?
