Stuck on Installer:Preparing for hours
rs2.bull
Post by rs2.bull »
Ignition seems to work but the i3 just hangs on the Installer:Preparing screen. Have tried for 4 or 5 hours now.
xml attached
Thanks for any advice,
AlexCH
Re: Stuck on Installer:Preparing for hours
Post by AlexCH »
Same here
stonewellmark
Post by stonewellmark »
Same here, finally unpluged it and tried updating via "ignition". It seemed to work. Now it wont upload a tune to car, will fortunately return the stock tune. Seems to jump all over the place, while trying to do a tune, ie. chose 87 tune, tire size, speed limiter, then it jumps to screen asking if i want to load the diablo tune...um no.
AlexCH
Post by AlexCH »
Are you already working on a solution or at least analyzing :?:
rs2.bull
Post by rs2.bull »
I haven't heard a thing on this issue yet.
Hopefully soon.
AlexCH
Post by AlexCH »
I am now in contact by e-mail with the support. Till now, no solution found.
Please update and try again, this should be resolved.
rs2.bull
Post by rs2.bull »
I tried again and my inTune i3 never gets past this screen.
I posted my info file at the start of this thread.
AlexCH
Post by AlexCH »
Same here. It also gets stuck with the same screen.
Problem is not solved.
If you reboot the device does it behave normally or boots up and gets stuck there again?
AlexCH
Post by AlexCH »
I gets stuck there again.
If it is connected to the computer (after it gets stuck after updating with ignition), it connects as a drive and disconnects again,.... and again connects and disconnects.... till you delete the update file manually.
After deleting the update file, it stays connected as a drive, but it only shows the background on the display, no GUI.
(Sorry for the bad english. I am from Switzerland)
please post the current info.xml file from the i2 drive.
AlexCH
Post by AlexCH »
I am abroad till Monday. I will post the xml on Tuesday.
AlexCH
Post by AlexCH »
Attached there is the currenct info.xml
AlexCH wrote:Attached there is the currenct info.xml
please update it again now and let me know if its good after its done.
Return to “Ignition updater”
