2005 Ford F150 5.4 Speedometer Correction
ecl351
Post by ecl351 »
I am not able to correct my speedometer by changing the tire revs and gear ratio on my T1000. The T1000 seams to take the corrections but my speedo is off by 4 mph no matter what ratio or tire revs I put in. This is for a 2005 Ford F150 5.4
Re: 2005 Ford F150 5.4 Speedometer Correction
are you changing the enable tire change param as well?
petemitchell2
Post by petemitchell2 »
Just bought the Trinity for the exact same year make model truck. I could not see where you change your tire size
petemitchell2 wrote:Just bought the Trinity for the exact same year make model truck. I could not see where you change your tire size
select the tune then pick modify tune/modify parameters then go to axle ratio or tire size menu.
Return to “Trinity Ford Gas”
