Error Message: "This vehicle is currently not Supported
I purchased the I3 tuner. After numerous updates, I keep receiving the following error message: "This Vehicle is currently not supported"
Please advise on resolving this matter. Attached is my info.xml
Re: Error Message: "This vehicle is currently not Supported
the device should be reset, can you give us a call today with the tool powered up so we can reset it?
Mikal,
My working hours conflict with your working hours, including time-zone. Only if you was available on weekends would be perfect but that's not the case. Adam Sterling Briggs. Powerteg Tech Support, forwarded me an email, indicating that I need to download the Ignition software from Diablosport website instead from the device. When I get home, I will uninstall Ignition and download from the website, plug in the device for updates and again try to upload a tune. Hopefully, this will solve the issues. If not, I will take off from work and call you to reset the device as you suggested. Additionally, I will update you tomorrow on the outcome.
Mike,
I download the software from the website. When performing updates the system got suck the following: "Interrogating device".
ignition got stuck there?
yes, the software get stuck there
Mike,
Well is the I3 tuner is getting a message of updates been completed when the device is connected to my computer. However, when plug in the car, the I3 tuner is keep repeating this vehicle is not supporting and an update is required. I did the update about three times and each time system shows updates are completed on the computer but vehicle is not supporting and an update is required
Please help
Please help
please post the current info.xml file from the i3 drive.Redlee wrote:Mike,
Please help
Mike,
I will post the current info.xml file tonight once I get home from work.. Thanks.
Mike,
Current file attached.
well, it says its married.Redlee wrote:Mike,
we should reset the device.
Can you give us a call with the tool powered up in the vehicle so we can sort this out?
Mike,
Because of the time zones (Pacific), I will call you tomorrow, December 6, 2017.
Frederick
Frederick
