have a 2004 SRT4, larger turbo, injectors, and custom tune, failed smog plug in test. TUNER had 02 sensor delete and wrote a tune only for the test. By the way cat delete. Downstream 02 sensor has a spacer. Drove the car 60 miles and still the same. See attached pdf for test results/
Please helpppppp Have diablo 7134
Smog test failure
JohnBorg158
Smog test failure
- SmogTest-Nov_28_2017_3-55-28-PM.pdf
- smog test
- (110.99 KiB) Downloaded 497 times
Re: Smog test failure
did you drive around long enough to set the monitors after loading the new tune?
JohnBorg158
yes I drove 200 miles and still same failuresmikel wrote:did you drive around long enough to set the monitors after loading the new tune?
amount miles doesn't matter as much as the number of "drive cycles" that have been completed..
