I have a 2017 GMC Yukon with the 5.3 and I have successfully installed a tune to it, however, the only thing I want to modify is the active fuel management. When I choose the afm to be off, it still works no matter how many times I tune it. All I want is stock ecu tune with AFM disabled. Is there an update for this I am missing?
Thank you in advance for the help and a happy new year to all!
I2 disable afm not working
Re: I2 disable afm not working
make sure your inTune i2 has all the latest updates and then try again.. it may not have the fix in it, since the i2 was discontinued a while back, and the fix for the issue came out recently...
brendan4862
I will try updating again. I was having an issue earlier with the i2 always saying there was an update available through Ignition. No matter how many times I updated it, there was always another update. Once I try again this evening, I will post back here my result.
Thank you MonteSS
Thank you MonteSS
there was a bug where this param was backward on 17 trucks, so try setting it to ON
brendan4862
That did it! Changed ‘afm/dod’ To ‘on’ and it worked. Thanks everyone!
glad to hear it.
This will be fixed in the next GM tune database thats released.
glockman49
Mike,
Has this bug been fixed? I'm going in today to redo mine if you have updated the software to be rid of that bug?
