initial tune and retune question
chile
Post by chile »
Hello,
I have 2009 Silverado with a 5.3L. I recently bought a intune to give a tune and change the tire size. I had to update twice before it would recognize my truck. It was able save the stock ECM and TCM (which i can see when hooked to my computer). Then it loaded the tunes with the changed parameters I put in i.e. tire size, firm shift, and shut off DOD. But then after writing and loading tune. It said failure occurred writing fail log.
The truck does fine and appears the tune is working. After that I tried log some driving around and the intune froze. I tried to put the truck back to stock and it froze again. I want to retune it to change some other things. I'm afraid to try to update it and lose the stock tunes.
Any info will help alot.
Re: initial tune and retune question
please post the info.xml file from the intune drive so we can check it out.
chile
Post by chile »
I was also wondering if I should reset the the adaptive trans table.
info.xml
(3.09 KiB) Downloaded 390 times
there is no adaptive trans setting that you can adjust/reset...
chile
Post by chile »
I know that thru the intune you cant but I have access to a snapon scanner.
dmoore
Post by dmoore »
my tuner did same with no updates has this been solved
chile
Post by chile »
Nothing Yet. Afraid to try to update it.
chile
Post by chile »
So my intune keeps freezing. When I trying to do anything from adjusting some parameters or returning back to stock. I go to the "turn you ignition key on dont start your engine" screen. Then the circle spinning thing stops. It even stops when I try to datalog. I searched and saw that there might be reset for the registry. Any help would be great thanks.
Registry number : FF2EC3 3B1706 2BC6E6 36F288 CDF844
info.xml
(3.09 KiB) Downloaded 332 times
