so i have a dsp for my srt4 neon, i had it dyno tuned for e-85 now i have a issue i do not have the file its not on my dsp and i never backed it up.
i have the e85 tune on my ecu i want to back it up because i need to add a little fuel in some areas as i fixed a boost leak, my issue is i cannot find any way to copy my current tune in my ecu when i use the computer its trying to pull the last written tune from my dsp but its not there, it shows my last written tune was custom dsp e-85 tune
the question is how can i get my current tune out of the ecu? its married to my vin it should read it
i don't mind loosing the "factory tune" as i can never use it
can i reset the tool so it will try making a stock tune backup some how without un marrying it to my car i don't want to have to pay that 200 fee i seen they charge
lost modified tune
Re: lost modified tune
if the custom tune is locked you may not be able to export it as a last tune written.
You can try reloading the custom tune then see if you can export a LTW, but ideally your tuner still has a copy of the tune he sent you and can make changes to that if needed.
d.gilcrease5
My problem is my local tuner closed shop and is mia
it is not locked i have pulled it and modified it before, it is just some how i erased it off the hand held. there really has to be some way to do it, i paid for the tune i paid for the turner the info is there but it dose not let me download it... or extract it if i reset the tuner would it copy my current tune thinking it was the original file? is there even a way to reset the tuner without loosing my vin info and my vehicle married status?
and i cant try to reload the custom tune because the file is mia off my tuner and i never made a laptop backup since i never thought any of this would be a problem
have you tried to export a copy of the last tune written?
d.gilcrease5
yes i have, it shows last tune written custom_e85 but when i tried to export it it says no file, i must have deleted it off my hand held. i just need a way to get the tune out of the ecu, i was told that the dsp cannot due that even if i pay to un marry or re marry it to try and get it as a copy of my "stock tune" or if i even paid for a upgrade to the newer versions my current tune seems to be lost and un retrievable even tho its in my ecu right now!
i know my hp tuner will pull it out but then i would have to pay for dodge credits and at the point i would just end up dropping the dsp which i don't want to do real easy to make a quick adjustment
if i cant get the tune backed up im down 900 dollars for the current tune and dsp and i will need to either go to another tuning platform to retrieve it or spend another 4 or 500 on another dyno tune, this really sucks because it should not work like this but it is also my fault for not backing it up
