Stuck at please wait
This section of the forum is for discussion relating to the use of the T2 EX tuner/monitor on GM vehicles.
Re: Stuck at please wait
OK, I am aware of this, and working with engineering to sort it out and get it working properly for you.
nathanhawkins777
Post by nathanhawkins777 »
We got it to push a different tune after I re-installed the factory tune.
So I re-installed the factory tune then went to customize the diablo tune and it hung up on the please wait screen after I selected the customize option.
So as it stands now, I can install a different tune if I re-install the factor tune first but I cannot customize the new tune before loading it into the vehicle.
yeah, we are seeing this and fixing it asap.
nathanhawkins777 wrote:We got it to push a different tune after I re-installed the factory tune.
this is resolved. Please update your device with ignition then you should be able to modify params at will.
Return to “T2 for GM”
