Power numbers
Bamatechjon
Power numbers
Sorry if this has been asked , What are the power / torque numbers for the tunes , 87 , 91 , 93 , Diablo is what shows on my tuner . 2004 Silverado 4x4 5.3ltr. , I Have programmed with Diablo tune , 1 percent upshift increase and 12 psi line pressure on upshift -.25 percent shift time decrease also . all I can say Is Wow what a difference the tune made . What would give me the best performance numbers and feel ?
2004 Silverado Z71 4x4 5.3 256000 miles
1987 Monte Carlo SS 5.7
Re: Power numbers
gains there are a little more than 20 rwhp, and 20-25 ft/lbs over stock
Bamatechjon
Re: Power numbers
is that across the board if so the 87 tune is better than the 93 tune or diablo ?
Re: Power numbers
The Diablo Tune is the 91/93 octane tune.. use this tune when using good 91/93 octane gas.. will have the most gains with this tune since the timing is set higher for the higher octane gas.
the 87 octane tune is for 87/89 octane gas, and uses stock timing settings.
Bamatechjon
Re: Power numbers
06MONTESS what is the difference between the diablo tune and the 91/93 tune ?
Re: Power numbers
they are the same thing.
