Template not Found
Template not Found
Why when I try to open this tune I am not finding the template or the family file? I don't do much with GM but in this case I need to disable rear o2s. The file attached is the last written tune. When ever I open it in Chipmaster and finally get to the scalars and edit "X_Diagnostic Trouble Codes" info where I assume I can turn them off, it crashes Chipmaster.
Re: Template not Found
did you rename the file?
try opening the backup as the fixed file and the ltw as the tuning file.
opens and works fine for me.. I'm using CMR 5.3.0.16...
